travis14
Mar 18, 2021Aspirant
router won't connect to internet unless I connect computer to LAN
Router Firmware: V1.0.0.48 Modem: Spectrum Business - Technicolor ET2251 OS: macOS / IOS This is at my office and I can't access modem since its locked in a closet somewhere but when I arrive i...
travis14
this is specturm's modem (Technicolor ET2251) and they manage it. my office is in a building with other businesses so the closet probably has multiple modems in there, but its a simple modem with coax and ethernet port so nothing else should be connected to the modem itself. I'm not sure how they manage the network.
Mar 18, 2021Guru - Experienced User
I'm more curious if its a shared connection. As it in goes modem--->router---->your office.
So if they have something else connected to the modem
- travis14Mar 18, 2021Aspirant
I'm not sure. I don't think my setup is anything unusual. I'm relatively new to the building but I can't imagine other offices living with this problem. In fact, I would assume other offices may have only wireless connections to their router/modem setup. I just don't know why everything works fine if I have just one device connected to LAN. If its not an easy config setting or something, I may just try a different router.
- plemansMar 18, 2021Guru - Experienced User
I'm trying to figure out if you have a double nat that could be causing your issue.
https://kb.netgear.com/30186/What-is-Double-NAT
If they have a modem + router setup, when you attach yours it could be causing issues.
