GUBL4's avatar
GUBL4
Follower
Sep 13, 2021
Router won't connect to internet
I connected modem to router , router to computer and can't get internet. connect modem to computer I get internet, I changed cables , same results , Powered systems off and on , same results On router , WAN light is solid amber output light blinks a while, up to two hours then turns solid amber please advise Thank you
  • FURRYe38's avatar
    What router model do you have? R####?
  • michaelkenward's avatar
    michaelkenward
    In the right order?
    • Turn off and unplug modem.
    • Turn off router and computers.
    • Plug in and turn on modem. Wait 2 minutes for it to connect.
    • Turn on the router and wait 2 minutes for it to connect.
    • Turn on computers and rest of network.
