ambimom
Sep 21, 2019Aspirant
router won't login on Chromium based browser
I have used a Chromium based browser for years (Vivaldi) and have never had any difficulty logging into the router, but all of a sudden in the latest iteration of Vivaldi, this is what happens. I fill in all the data, and it just loops back to this screen.
Luckily I am able to log in using Safari.
Don't understand why this is happening. Any suggestions?
Found the solution, thanks to Dustin. This is what I did and I'm back in. THANK YOU
a. Paste chrome://flags/#http-auth-committed-interstitials into a Google Chrome Browser
b. Click the down arrow to change from Default or Enabled to Disabled
- ambimomAspirant
Thanks for that report.
We can add Chromium to the browsers that have caused hiccups after an update.
Be warned that some things won't work in Safari. Password recovery, for example.
