rikeo
Jan 23, 2016Tutor
routerlogin does not ask for username and password
 Hi.  Last week I bought the Nighthawk X6 R8000.  It's working great so far, with just one problem.  Whenever I visit routerlogin.net on my internet browser, I don't get the prompt asking for my usern...
- Jan 27, 2016Hi rikeo, Try reloading the firmware and perform a factory reset. Manually reconfigure the router instead of loading the backup file.
Retired_Member
Jan 25, 2016I don't use ready share. Maybe it's a bug, see if disabling RS make a difference. Try a factory default, revert to earlier FW and or contact support
JamesGL
Jan 25, 2016NETGEAR Employee Retired
Hi rikeo,
I would suggest contacting support team to further isolate or investigate on your issue.
