rikeo
Jan 23, 2016Tutor
routerlogin does not ask for username and password
 Hi.  Last week I bought the Nighthawk X6 R8000.  It's working great so far, with just one problem.  Whenever I visit routerlogin.net on my internet browser, I don't get the prompt asking for my usern...
- Jan 27, 2016Hi rikeo, Try reloading the firmware and perform a factory reset. Manually reconfigure the router instead of loading the backup file.
mediatrek
Jan 27, 2016Virtuoso
By chance does your system use any 2016 Kaspersky products? If so, that is the culprit. Disabling Kaspersky 2016 features will not work. You have to totally uninstall it and use an older Kasperksy product version (ie- 2015 line). After uninstalling the Kaspersky 2016 product, you can then access the router's web UI without an issue.
