rikeo
Jan 23, 2016Tutor
routerlogin does not ask for username and password
 Hi.  Last week I bought the Nighthawk X6 R8000.  It's working great so far, with just one problem.  Whenever I visit routerlogin.net on my internet browser, I don't get the prompt asking for my usern...
- Jan 27, 2016Hi rikeo, Try reloading the firmware and perform a factory reset. Manually reconfigure the router instead of loading the backup file.
rikeo
Feb 28, 2016Tutor
I am contacting support directly as there is not an apparent fix at the moment.
JamesGL
Mar 06, 2016NETGEAR Employee Retired
Hi rikeo,
Are you now in contact with support team? If yes, please PM me you case number.
- skeeminMar 27, 2016AspirantI too have a nighthawk x6 r8000 and am having the same issue. I recently upgraded the firmware to the latest version available (V1.0.3.4_1.1.2 ) and noticed the problem immediately after attempting to setup ReadyShare. I am willing to bet this has something to do with it. I no longer am prompted by any device on my network to login with the admin password. If I do not have to do a factory reset I'd prefer not to as there is a lot to have to document and set back up. Any updates on this issue?
