AngelaV
Feb 09, 2017Aspirant
"routerlogin.net" keeps saying I must be connected to my router's WiFi, even though I am
I was having connectivity issues with my Verizon Fios router. They sent out a technician and the problem was fixed. After my netgear wifi router was reset, I attempted to go to "www.routerlogin.com" ...
- Feb 22, 2017There was a white cable running from the FIOS to the NetGear. It's showed in the old pictures. The new pictures is how it's currently configured and it's worked like a dream since the removal of the white cable.
So to anyone with the same issues as mine, check your cables and make sure there aren't extras. All that's needed is the Ethernet cable connecting the FIOS router to the NetGear and the plug in from the NetGear to the outlet. Make sure you reset when removing a stray, unnecessary cable. It worked for me.
Adewale
Feb 09, 2017Luminary
your verizon FiOS is a modem/router so i belive you're not connected to your router but you are accessing the internet through the FiOS. a second possibility is that your Netgear router has been configured as an access point
Solution:
1. disable the router function of the FiOS so you can isolate your Netgear router signals (assumption is that your router is not working as an AP).
2. if you have to, do a hard reset on your router, switch off the wifi adapter on your macbook and connect to the netgear router via an ethernet cable. and try to login to the router UI again
