AngelaV
Feb 09, 2017Aspirant
"routerlogin.net" keeps saying I must be connected to my router's WiFi, even though I am
I was having connectivity issues with my Verizon Fios router. They sent out a technician and the problem was fixed. After my netgear wifi router was reset, I attempted to go to "www.routerlogin.com" ...
- Feb 22, 2017There was a white cable running from the FIOS to the NetGear. It's showed in the old pictures. The new pictures is how it's currently configured and it's worked like a dream since the removal of the white cable.
So to anyone with the same issues as mine, check your cables and make sure there aren't extras. All that's needed is the Ethernet cable connecting the FIOS router to the NetGear and the plug in from the NetGear to the outlet. Make sure you reset when removing a stray, unnecessary cable. It worked for me.
AngelaV
I'm not very knowledgeable on this topic so I don't know if I'll answer this well.
I'm connected to the Netgear network and I can access the Internet just fine. Our FIOS had crapped out and we hadn't been able to connect to the Internet. Now that the router has been replaced, the Internet works again.
I have no idea how to disable FIOS router function either. And we'd prefer not to mess too much with the FIOS because they just sent us a new router and fixed it, and if it craps out again we get charged by Verizon.
LeeH
Feb 09, 2017Prodigy
If you call your ISP (Verizon), they should be able to configure your modem as a bridge instead of being a router remotely at no charge to you.
- William10aFeb 09, 2017Master
Bright house modems also have a router made in to them you can access at a limit level to get some control but if you use both the modem and router functions you paids rental fees on both.
