AngelaV
Feb 09, 2017Aspirant
"routerlogin.net" keeps saying I must be connected to my router's WiFi, even though I am
I was having connectivity issues with my Verizon Fios router. They sent out a technician and the problem was fixed. After my netgear wifi router was reset, I attempted to go to "www.routerlogin.com" ...
- Feb 22, 2017There was a white cable running from the FIOS to the NetGear. It's showed in the old pictures. The new pictures is how it's currently configured and it's worked like a dream since the removal of the white cable.
So to anyone with the same issues as mine, check your cables and make sure there aren't extras. All that's needed is the Ethernet cable connecting the FIOS router to the NetGear and the plug in from the NetGear to the outlet. Make sure you reset when removing a stray, unnecessary cable. It worked for me.
AngelaV
But would doing that help the situation with the NetGear router login?
- William10aFeb 09, 2017Master
If the modem/router is in bridge mode the router including it's wifi will be disable and the Netgear router can function normally.
Get the make and model of your modem and down the manual for it or you may have to your isp set the modem to bridge for you depending on the degree of control they have over the modem.
- michaelkenwardFeb 09, 2017Guru - Experienced User
AngelaV wrote:
But would doing that help the situation with the NetGear router login?Excellent question. The answer you got is not clear to me. It looks like a major detour from the issue in hand. I fear that we are getting lost in a fog of confusion.
Let's get back to basics. Things seem to be working, so do you really need to change anything?
Oh, and your first message referred to a "Verizon Fios router". I assume that this is a modem/router.
Did you follow this:
Re: "routerlogin.net" keeps saying I must be conne... - NETGEAR Communities
when you restarted the network? The order is important when you have a modem and a router talking to each other.
