AngelaV
Feb 09, 2017Aspirant
"routerlogin.net" keeps saying I must be connected to my router's WiFi, even though I am
I was having connectivity issues with my Verizon Fios router. They sent out a technician and the problem was fixed. After my netgear wifi router was reset, I attempted to go to "www.routerlogin.com" ...
- Feb 22, 2017There was a white cable running from the FIOS to the NetGear. It's showed in the old pictures. The new pictures is how it's currently configured and it's worked like a dream since the removal of the white cable.
So to anyone with the same issues as mine, check your cables and make sure there aren't extras. All that's needed is the Ethernet cable connecting the FIOS router to the NetGear and the plug in from the NetGear to the outlet. Make sure you reset when removing a stray, unnecessary cable. It worked for me.
AngelaV
I do not have iThing. I actually had to look that up cause I've never heard of it.
michaelkenward
Feb 10, 2017Guru - Experienced User
It is just my way of referring to iPhone, iPad or iWhatever.
Netgear isn't great at supporting iStuff, unlike Android, well up to a point, but anything with a browser should be able to get into the web interface of a modem or router. Quite how much you can do when you get there depends on the device.
