AngelaV
Feb 09, 2017Aspirant
"routerlogin.net" keeps saying I must be connected to my router's WiFi, even though I am
I was having connectivity issues with my Verizon Fios router. They sent out a technician and the problem was fixed. After my netgear wifi router was reset, I attempted to go to "www.routerlogin.com" ...
- Feb 22, 2017There was a white cable running from the FIOS to the NetGear. It's showed in the old pictures. The new pictures is how it's currently configured and it's worked like a dream since the removal of the white cable.
So to anyone with the same issues as mine, check your cables and make sure there aren't extras. All that's needed is the Ethernet cable connecting the FIOS router to the NetGear and the plug in from the NetGear to the outlet. Make sure you reset when removing a stray, unnecessary cable. It worked for me.
AngelaV
Feb 12, 2017Aspirant
The only cable connected is a white cable. From "Aggregate 1" on NetGear to LAN 4 on FIOS.
William10a
Feb 12, 2017Master
That sounds like the netgear is access point not being used as a router.
The aggregate 1 and 2 are lan ports can be tied together as single port with a speed of 2gb if connect to lan card or nas servers that support's it.
So the isp modem/router see and answer the login call from the computer or other device.
Was set up that way by your isp or a mistake ?
If it meant to be a router the white lan cable should be on the wan(internet)port then not on one of the six lan ports.
