AngelaV
Feb 08, 2017Aspirant
"routerlogin.net" keeps saying I must be connected to my router's WiFi, even though I am
I was having connectivity issues with my Verizon Fios router. They sent out a technician and the problem was fixed. After my netgear wifi router was reset, I attempted to go to "www.routerlogin.com" ...
- Feb 21, 2017There was a white cable running from the FIOS to the NetGear. It's showed in the old pictures. The new pictures is how it's currently configured and it's worked like a dream since the removal of the white cable.
So to anyone with the same issues as mine, check your cables and make sure there aren't extras. All that's needed is the Ethernet cable connecting the FIOS router to the NetGear and the plug in from the NetGear to the outlet. Make sure you reset when removing a stray, unnecessary cable. It worked for me.
AngelaV
Feb 12, 2017Aspirant
The only cable connected is a white cable. From "Aggregate 1" on NetGear to LAN 4 on FIOS.
Feb 12, 2017Guru - Experienced User
That's the problem. "Aggregate 1" is one of the 6 LAN ports. The two "aggregate" ports can be used with an advanced feature called LACP, so they are named differently from the other LAN ports.
It needs to go to the internet port - which should be yellow. It's on the far left as you are looking at the back of the router. There's a picture on page 14 of the user manual here: http://www.downloads.netgear.com/files/GDC/R8500/R8500_UM_4jan2016.pdf
