AngelaV
Feb 09, 2017Aspirant
"routerlogin.net" keeps saying I must be connected to my router's WiFi, even though I am
I was having connectivity issues with my Verizon Fios router. They sent out a technician and the problem was fixed. After my netgear wifi router was reset, I attempted to go to "www.routerlogin.com" ...
- Feb 22, 2017There was a white cable running from the FIOS to the NetGear. It's showed in the old pictures. The new pictures is how it's currently configured and it's worked like a dream since the removal of the white cable.
So to anyone with the same issues as mine, check your cables and make sure there aren't extras. All that's needed is the Ethernet cable connecting the FIOS router to the NetGear and the plug in from the NetGear to the outlet. Make sure you reset when removing a stray, unnecessary cable. It worked for me.
AngelaV
Feb 13, 2017Aspirant
I don't understand what you mean by plug Verizon Modem to NetGear Internet Port.
We attempted moving the cables as suggested earlier and all that happened was the Internet slowed or even stopped. So we put it back. NetGear Genie popped onto our screen and asked us if we wanted to switch to "Router Mode". We tried to do it but I wasn't sure what to enter in the fields they asked for.
So we're just leaving everything as it, because the Internet works. Thank you for your time and help.
William10a
Feb 13, 2017Master
I should said plug to lan cable in the wan port sometimes I think in short cuts and forget that have worked many of electronics and electric wiring I get the word mixed up sometimes as many mean the something in different fields.
