AngelaV
Feb 09, 2017Aspirant
"routerlogin.net" keeps saying I must be connected to my router's WiFi, even though I am
I was having connectivity issues with my Verizon Fios router. They sent out a technician and the problem was fixed. After my netgear wifi router was reset, I attempted to go to "www.routerlogin.com" ...
- Feb 22, 2017There was a white cable running from the FIOS to the NetGear. It's showed in the old pictures. The new pictures is how it's currently configured and it's worked like a dream since the removal of the white cable.
So to anyone with the same issues as mine, check your cables and make sure there aren't extras. All that's needed is the Ethernet cable connecting the FIOS router to the NetGear and the plug in from the NetGear to the outlet. Make sure you reset when removing a stray, unnecessary cable. It worked for me.
AngelaV
Feb 15, 2017Aspirant
I moved the white cable to another port (that doesn't have a label but it's not Aggregate). Let's see how that goes.
- William10aFeb 15, 2017Master
Remove the white cable unneeded it should not even be connected to the router or modem just a extra cable causing problems the yellow cable from the modem's lan port to the netgear's internet port is all you need and the black cable should be on one of the netgear's lan ports.
