madbrain
Jan 26, 2017Luminary
Routerlogin.net no longer working on wired LAN - firmware regression
Updated my R7000 to V1.0.7.6_1.1.99 . Now, when I go to routerlogin.net from my desktop, I get a page that states : "You are not connected to your Router’s WiFi network. To access routerlogin.net, ...
- Jan 28, 2017
I wanted it fixed indeed, not worked around.
Thanks for pointing me to the anti-virus direction. I do use AVG. Looks like a recent AVG update broke it - disabling AVG temporarily, routerlogin.net works fine - turning it back on, it's broken.
Sorry about the erroneous bug report on firmware. Both my R7000 firmware update and AVG anti-virus update happened in the same timeframe. I will take my complaint to AVG.
William10a
Jan 26, 2017Master
Any firmware updates ?
Using Genie ?
Any changes to your setup ?
What os are you using ?
- madbrainJan 26, 2017Luminary
William,
1) Firmware update - duh, yes, this regression happened right after the router's firmware upgrade
2) no idea what Genie even is
3) no changes whatsoever, only router firmware upgrade
4) Windows 10 x64
- William10aJan 26, 2017Master
Genie is the software program what allows you to setup the router from your desk top with out logging in to the router by a browser in the router.
