HarryZ
Apr 08, 2021Aspirant
routerlogin.net not working after disabling DHCP
Walked into a new account that was having internet troubles. Fixed the issue with their ISP. Found that there was a Netgear Nighthawk AX8, Model RAX75 "downstream" from the ISP modem. I also noticed ...
- Apr 09, 2021
> [...] I will try connecting the cable from the Technicolor to the LAN
> port on the Netgear and see what happens. [...]I wouldn't do that. That was a possible explanation for what you
reported, not a suggested course of action.> [...] look in the User Manual for "Set up the router as a WiFi access
> point". [...]Still my advice.
antinode
Apr 08, 2021Guru
> [...] I just disabled DHCP on the Netgear and let the ISP router take
> care of assigning IP addresses for all the PCs.
Not completely wrong, but not good enough.
> [...] Some other secret way of doing this?
So well hidden that you might never guess the key...
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Reset" and/or "Factory Settings".
When that's done, and you can again get to the management web site,
look in the User Manual for "Set up the router as a WiFi access point".
(That will, among other things, disable the DHCP server on the RAX75.)
