HarryZ's avatar
HarryZ
routerlogin.net not working after disabling DHCP
Walked into a new account that was having internet troubles. Fixed the issue with their ISP. Found that there was a Netgear Nighthawk AX8, Model RAX75 "downstream" from the ISP modem. I also noticed ...
  • antinode's avatar
    antinode
    Apr 09, 2021
    > [...] I will try connecting the cable from the Technicolor to the LAN
    > port on the Netgear and see what happens. [...]
       I wouldn't do that.  That was a possible explanation for what you
    reported, not a suggested course of action.
    > [...] look in the User Manual for "Set up the router as a WiFi access
    > point". [...]
       Still my advice.
