HarryZ
Apr 08, 2021Aspirant
routerlogin.net not working after disabling DHCP
Walked into a new account that was having internet troubles. Fixed the issue with their ISP. Found that there was a Netgear Nighthawk AX8, Model RAX75 "downstream" from the ISP modem. I also noticed ...
- Apr 09, 2021
> [...] I will try connecting the cable from the Technicolor to the LAN
> port on the Netgear and see what happens. [...]I wouldn't do that. That was a possible explanation for what you
reported, not a suggested course of action.> [...] look in the User Manual for "Set up the router as a WiFi access
> point". [...]Still my advice.
antinode
Apr 09, 2021Guru
> point". [...]
Still my advice.
antinode
Apr 09, 2021Guru
Note that if the RAX75 gets its IP address using DHCP, then it'd make
some sense to reserve an address (preferably memorable) for it in the
DHCP server on the main router. When it's configured as a WAP, those
"routerlogin" names might work from a system which is connected directly
to the RAX75, but not from other places on the LAN. Its (new) LAN IP
address should work from anyplace on the LAN.
