zach8870
Jan 17, 2019Aspirant
routerlogin.net refused to connect (r7000p)
R7000P here. Just did a firmware update (as I hadn't done one since I got this thing and I thought it was time for an upgrade) and I can see why people complain about updating firmware. If I try to a...
- Jan 17, 2019
The router has a reset hole at the back. Use a pin to push it in so you can factory reset it... then use user "admin" and pass "password" to login
microchip8
Jan 17, 2019Master
- myerswJan 17, 2019Master
And another satisfied customer where firmware update breaks things requiring, hopefully only a reset to fix or maybe a fall back to previous version. Properly designed firmware should update without issues, including have to reset. Unfortunately the Netgear engineers are off wandering in a wilderness somewhere. Only time a reset should be required is when a major change is made to the firmware and that should be noted in the notes.
- zach8870Jan 18, 2019Aspirant
Thanks, a reset worked and now I can access the page as normal.
