zach8870's avatar
zach8870
routerlogin.net refused to connect (r7000p)
R7000P here. Just did a firmware update (as I hadn't done one since I got this thing and I thought it was time for an upgrade) and I can see why people complain about updating firmware. If I try to a...
  • microchip8's avatar
    Jan 17, 2019
    The router has a reset hole at the back. Use a pin to push it in so you can factory reset it... then use user "admin" and pass "password" to login
