zach8870
Jan 17, 2019Aspirant
routerlogin.net refused to connect (r7000p)
R7000P here. Just did a firmware update (as I hadn't done one since I got this thing and I thought it was time for an upgrade) and I can see why people complain about updating firmware. If I try to a...
- Jan 17, 2019
The router has a reset hole at the back. Use a pin to push it in so you can factory reset it... then use user "admin" and pass "password" to login
microchip8
Jan 17, 2019Master
zach8870
Jan 18, 2019Aspirant
Thanks, a reset worked and now I can access the page as normal.
