parishemilton
Apr 06, 2021Follower
routerlogin.net :Why can't I connect to Routerlogin net?
When a user enables the location feature in his router during the Netgear Router setup process, your router automatically identifies your location and assigns the language to your router according to the location. If a user is not comfortable with the language that his router has provided then you can also change it through the web interface of the routerlogin.net window. All you have to do is to log in to the web interface of Netgear Router and have to select the desired language from the menu list located in the upper right corner of the window.
No RepliesBe the first to reply
