Izzyp7029
Aug 31, 2016Aspirant
Router's white Ethernet LED flashes continuously (at about 5 flashes per second)
The white Internet LED on my Netgear router (R7000 Nighthawk, AC1900) is flashing continuously (approx. 5 times per second), and it is causing the Link LED on my modem to flash constantly. It started...
- Sep 04, 2016
Show Statistics is one of the purple buttons under the Internet Port pane.
VE6CGX
Sep 03, 2016Master
Nothing wrong. Indicates line activity(which means the port is alive and working)
- Izzyp7029Sep 04, 2016Aspirant
Thanks for your input. I'm just trying to understand what's different from a week ago when I power-cycled my wireless router. Prior to that event, the "Internet" LED on my router flashed whenever anyone within my network accessed the internet. When nobody was accessing the internet that LED was steadily on, or it would flash once every 5 - 10 seconds (I assumed that was a polling function). After I power-cycled the router it has been flashing non-stop at a rate of about 5 flashes per second. Reseting it (with the reset button on the baack) didn't resolve the problem. As I said, I'm just trying to understand what's wrong/different, and what (if anything) I can do to return it to the way it worked before. Also, is this something I should be concerned about (from a security perspective)? It is not that my communications are of a high-security nature. I just prefer my communications to be private (as much as that is possible in today's world). Thanks again.
