Bern64
May 11, 2021Aspirant
Routeur AC1900 R7000 - Extension du réseau - Mesh
Bonjour à tous, J'ai actuellement un routeur R7000. Je désire installer, à la maison, un réseau Wifi Mesh à partir de celui-ci. Quel répeteurs devrais-je acquérir (j'aimerais en avoir 2)? Le EX7000...
Bern64
plemans Thank you for your answer.
If I go for the Netgear Orbi installation, I would have the following configuration:
1 router (from the tel company) not emitting a wifi but connecting 1 Orbi in access point (RJ45), a second Orbi also in access point because of the thick wall and add the third Orbi as mesh extenders.
Doing that, would I have a whole wifi mesh in my house, without need for changing passwd and so on?
Thanks for your reply,
Best regards,
Bern64
May 11, 2021Guru - Experienced User
Yes. The Orbi system can be ran in access point mode.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
It also supports both wired and wireless backhaul connections and still function properly as a mesh.
