jumanji1969
Nov 17, 2016Aspirant
Routing problem
Hi, I bought it long time ago, exactly when they launched it. i had vdsl connection, it was working great. i mean my network was great, i have a popcorn hour media player and Asustor NAS, I never h...
- Nov 24, 2016
Hi jumanji1969,
Just to check if it is the VLAN, try disabling the VLAN and observe the connection between the devices. Reconfigure it after the observation.
JamesGL
Community Team
Retired_Member
Nov 17, 2016ISP MODEM/ROUTER in bridge mode connected to R8000 by WLAN explain this?
Have tried using ISP modem/router in router mode and using r8000 in AP mode?
- jumanji1969Nov 17, 2016Aspirant
i meant connecting the ISP modem/router from lan port to Netgear R8000 internet port (yellow one).
using the netgear in AP, won't reduce it's capacity?
the internet speed is great, streaming online is great.
the main issue is that devices connected wired can't communicate with the wireless devices properly.
all the devices were connected in the same way, what i changed is the VLAN mode, to be able to be connected to the new ISP fiber optic modem/router.
without VLAN mode there was no way to be connected.
thank you in advance & regards,
- JamesGLNov 22, 2016NETGEAR Employee Retired
Hi jumanji1969,
1. Where did you configure the VLAN mode? Is it on the router or your modem?
2. Are the HD movies being watched locally or via Interner(Online Streaming)?
JamesGL
Community Team
