kjdeutin
Jun 17, 2021Follower
RS400 Reboots Itself
Hi, I have a Netgear RS400 that randomly reboots itself. I have tried using different power outlets with no luck. I have tried factory reset multiple times, and it works initially, only to repeat...
DarrenM
Jun 23, 2021Sr. NETGEAR Moderator
I suggest contacting support if the unit is going bad. https://www.netgear.com/support/contact.aspx
DarrenM
