PAPER512's avatar
PAPER512
Follower
Jul 06, 2017
Running a server with LTE R7100G
Hello, For some time I try to run a server on my network in order to reach for example my NAS or my security camera's from another location (so outside my own network). To my opinion I tried everything possible:
- I have a DDNS address (No-IP and also Netgear) and entered it in the router
- I tried to put the server in the DMZ
- I forwarded the port for the server
I use this modem/router with a SIM card only (4G network)
I do not come any further. I suspect that my provider (T-Mobile 4G network) is blocking this, but before I start to make a lot of noise there, is there somebody having an idea what I have missed or did not do? Thanks
  • Hi PAPER512,
    Check with T-mobile to make sure they are not blocking the connection.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi PAPER512,
    • JamesGL's avatar
      JamesGL
      Hi PAPER512,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
