novicenetwork
Apr 25, 2022Guide
Running CAT6 on outside of home
I've switched plans and instead of going mostly wireless, I purchased a Nighthawk Router and I'm cabling to all the rooms that need ethernet and the Nighthawk has the perfect number of LAN ports. My...
- Apr 25, 2022
CAT6A STP would be recommended for outdoor use.
Apr 25, 2022Guru - Experienced User
You should be able to. Thats the whole point of underground rated cable. And you're running it in a conduit for even better protection
