novicenetwork
Apr 25, 2022Guide
Running CAT6 on outside of home
I've switched plans and instead of going mostly wireless, I purchased a Nighthawk Router and I'm cabling to all the rooms that need ethernet and the Nighthawk has the perfect number of LAN ports. My...
- Apr 25, 2022
CAT6A STP would be recommended for outdoor use.
Apr 25, 2022Guru - Experienced User
novicenetwork
Apr 25, 2022Guide
Everything I have read says that the cable I bought should be good, just wanted some other opinions. 🙂 The way I'm planning on running it, there wont be a chance for water to get to the cable. I'll just have to cross my fingers at this point. Thank you for the advice!
