tjnintulsa
Jan 23, 2021Follower
Running Firmware for WNDR3400v3
Downloaded Zip & Extracted WNDR3400v3-V1.0.1.38_1.0.68.chk Type says "Recovered File Fragments" 6,813 KB When I right click/Open, double click or Click on "Open" Drop Down Box it either asks for an...
- Jan 23, 2021
> [...] Type says "Recovered File Fragments" [...]
Who, exactly, says what, exactly? Windows File Explorer? What does
_it_ know, other than that the file type is ".chk"?> When I right click/Open, double click or Click on "Open" Drop Down Box
> [...]Who said that you should do that?
> [...] OR am I doing something wrong. [...]
Yup. RTFM failure.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Upgrade the Router Firmware", and use the manual ("Locate and select
[...]") method.
Or:Fine print:
antinode
Jan 23, 2021Guru
Yup. RTFM failure.
[...]") method.
Or:
Fine print:
