Spisabab
Oct 17, 2021Aspirant
Rx7000 extender
My modem went out and had to buy a new one, now I can't get my extender to connect to it. What do I need to do? Please help!
Oct 18, 2021Guru - Experienced User
Need some details.
1. what modem/gateway did you replace it with (model)?
2. what method of setup are you using? WPS, using the installation assistant, or using the app?
3. where is it failing? What error are you getting? Details are key in helping out and determining where its failing/whats going wrong. Help us to help you
4. I take it you mean the EX7000 and not the RX7000 (there isn't that model number)?
If so, install guides/videos can be found here:
https://www.netgear.com/support/product/EX7000.aspx
