Itsall4fun
Nov 22, 2017Guide
Samsung Blu-ray player says the HTTP port is disabled
I am trying to connect my wired Samsung Blu-ray player to the internet and I keep getting the message that the HTTP port is disabled. I have tried assigning its own IP address and also entering the ro...
- Jan 22, 2018I installed a firmware update for the blu-ray player onto a flash drive and updated the player through that and it connected again finally. Guess the new router was not compatible with it before the update. I would try that.
TheEther
Nov 22, 2017Guru
I just Googled "Samsung Bluray http disabled"' and found this interesting link on another forum. Looks like either manually configuring a DNS server address on the Blu-Ray player or manually configuring a static IP, gateway address and DNS server address works.
- Itsall4funNov 22, 2017GuideHi thanks, I read that same post and tried everything it suggested to no avail.
- TheEtherNov 22, 2017GuruCan you provide some details about what you tried? Did you manually enter a DNS server address on the player? What address did you enter?
Did you try entering a static IP address as well as a gateway address? What did you enter?
Is your player obtaining an IP address from the router?- Itsall4funNov 22, 2017GuideYes I entered the DNS server address, static IP and gateway as listed in my router configuration. I added a photo to the original post of the network test screen on the player. It is obtaining an IP address.
