Stix18
Dec 06, 2021Aspirant
Samsung Blu-ray player says the HTTP port is disabled
I keep getting a http port disabled message. I've have set the ip and dns manually and used dhcp. I've set dns manually only with same result. I haven't been able to update firmware through USB. I nev...
michaelkenward
Dec 07, 2021Guru - Experienced User
Your "footer" says A7000. That is a WiFi USB Adapter. These don't work on "smart" TVs.
Depending on your Samsung player, you can either use wifi or wired Ethernet to connect to the Internet.
In my case,I find Powerline Ethernet to be more reliable and easier to set up than wifi.
Stix18
Dec 07, 2021Aspirant
It's a typo. I believe it's a AC7000. Definitely a Nighthawk 1900. I was finally able to update the firmware but still can't connect via a wired connection using methods used in the other thread.
