Stix18
Dec 06, 2021Aspirant
Samsung Blu-ray player says the HTTP port is disabled
I keep getting a http port disabled message. I've have set the ip and dns manually and used dhcp. I've set dns manually only with same result. I haven't been able to update firmware through USB. I nev...
joubert23
Feb 21, 2022Aspirant
Stix18 wrote:
I keep getting a http port disabled message. I've have set the ip and dns manually and used dhcp. I've set dns manually only with same result. I haven't been able to update firmware through USB. I never get the option through software update on the bd-d5100/za. It only wants to use the internet to update. The unit sees the USB if I view devices.
