guevarave
Sep 16, 2021Follower
Satellite showing Orange Light in App
Hi all,
I have a question similar to the below post, but with a plot twist-
https://community.netgear.com/t5/Orbi/Satellite-showing-Orange-Light-in-App/m-p/1925315
Like the OP in the previous post, an orange light is showing up in one of my two orbi satellites in the orbi app. However the difference is that, the closer satellite is showing up as amber/orange whereas the further satellite is green. They are connected in series like the other scenario. i.e. the green satellite is connecting to the orange one.
When I logged into the orbi web interface, it does indeed show the near satellite as poor, and the far one as good. Further, it showed that the far satellite is receiving 5ghz (green) whereas the near one is receiving 2.4ghz (poor).
I have tried moving the near satellite around to see if the signal improves, but it is not helping. I have checked and the firmware is up to date. I have also rebooted the router and turned the satellite off and on.
Could anyone suggest a solution to the problem? It doesn't seem to be the distance from the orbi router. Many thanks in advance.
1 Reply
Netgear has set up a community forum specifically for the Orbi App product. Most of the people who watch that forum are more likely to have experience with Orbi App and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
