KruseAnderson
Apr 22, 2022Aspirant
schedule change causes Error 400 Bad request R7000p
I have 3 routers with 2 set up as AP's. Main R7000p and AP's are an R7000 and R6900p. I am trying to set up IP blocking by schedule, but every time I try to change the default time from 00:00-24:00 ...
CrimpOn
Apr 22, 2022Guru - Experienced User
Is this an attempt to block a specific device on the network from access, as on page 47 of the user manual?
https://www.downloads.netgear.com/files/GDC/R7000/R7000_UM.pdf
Is the start time for the schedule earlier in the day than the end time?
(When I experimented with trying to block services "overnight" on a different Netgear router, such as 10pm to 6am, I found that it would reset at midnight. - which I consider a logical flaw in the software.) I never did get a 400 web error.
- KruseAndersonApr 23, 2022AspirantIt will be an attempt to block a device at bedtime, but at this point it is just trying to change the time from all day. If I even just uncheck the all day tick box and apply, I get the error, whether I change any times or not.
