paliwalrohit
May 20, 2024Tutor
Schedule Reboot for my Router
I've these two routers in my home wifi setup, one is configured as the main router and another as the Wi-Fi access point, I've noticed that once in a week or so, my devices will say not connected to ...
paliwalrohit
May 21, 2024Tutor
Regarding using the smart plug, what happens to a smart plug when internet connectivity is not there, both my routers have a router UPS connected, the small ones, so smart plug might not work else when I go out,I shall remove the UPS and put them directly into wall with smart plug in between.
May 21, 2024Guru - Experienced User
Each smart plug is different. I have a couple that'll work with a schedule even if they drop offline and others that don't function at all offline.
