shawn2001
Dec 24, 2023Aspirant
Screen mirror wont work on multiple devises
AC3000 model R7900P. Recently tried to us screen mirroring on my TV. Did not work, tried other TV same result. Updated all software on TV's and phone, Also updated router firmware. Still no suc...
shawn2001
Casting to two LG smart TV's and to a Sony DVD player with casting option. Casting from i-phone. Does not work in my house with the noted router. I-phone works to other devices at other homes (Hisense TV's). Used to work on all devices noted here but stopped working sometime in the past two months. If I could get it to work on one of these devices I would say it is not the router. But for all of them to have the same issue makes me suspect the router.
michaelkenward
Dec 24, 2023Guru - Experienced User
Anything that you can think of that has changed? Stuff like that isn't usually a case of spontaneous combustion.
Sounds right to me. Anything charged there? Got an old settings backup you could restore?
