christoepherr
Dec 12, 2020Tutor
Searching for Fiber Modem/Router
Hello Community, I am moving toa new home and getting CentruyLink Fiber Internet. I am trying to look for a modem/router combo so I don't have to use my ISP's. Having trouble finding the right pr...
Dec 12, 2020Guru - Experienced User
its not.
Netgear doesn't have any fibre modems.
The CAX80 is a cable modem and won't work.
but you can probably check with centurylink on just getting an ONT that you can connect your own router to.
Or if they do send you a gateway with integrated router, usually you can disable th router portion so you can use your own.
michaelkenward
Dec 13, 2020Guru - Experienced User
And the advantage of this is that you have separate router, which gives you a much larger choice of routers. Modem/router combos limit your options.
