Higgs22
Jul 02, 2024Aspirant
Security - Blocking Sites Does Not Work - Nighthawk R8500
I have a Nighthawk R8500, firmware V1.0.2.160. Advanced>Security>Block Sites does not work - at all. Blocking is set to "Always". Keywords are domains and keywords. Example: YouTube, youtube,...
- Jul 02, 2024
Most likely due to sites being HTTP(S) which NG routers can't block.
Might try using a DNS site service to help block sites, OpenDNS or NextDNS.
Also the R8500 is EoL:
Jul 02, 2024Guru - Experienced User
Higgs22
I have a Nighthawk R8500 firmware version 1.0.2.160. Can confirm that the block feature DOES NOT WORK. I have tried domains, keywords, IP addresses, etc. Nothing is blocked. It's a useless feature. Who programmed this? An intern?
