robdog1977
Feb 03, 2025Tutor
Security Firmware update for R8000 Nighthawk
I received an email this morning from NETGEAR emarketing@e.netgear.com saying I needed to do a firmware update on my Nighthawk R8000 running firmware V1.0.5.88_10.1.88 but after logging in and checki...
Feb 03, 2025Guru - Experienced User
NOVATROOP
Feb 06, 2025Aspirant
Can u tell me if this is also for the R8000 uk version firmware thank u
- FURRYe38Feb 06, 2025Guru - Experienced User
Yes.
- michaelkenwardFeb 06, 2025Guru - Experienced User
Actually, the answer is No.
That's because local versions of firmware are rare. They usually apply to everyone everywhere.
Those marketing emails go out from time to time and aren't usually related to a new firmware release. The clue is in the emarketing bit oi the the email address emarketing@e.netgear.com.
Here's the most reliable way of checking for new and installing firmware:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Disclaimer: Just another user with time on their hands.
