cmartorelli
Mar 06, 2020Guide
Security flaws if only used as access points
I have read the recient artical about the vulnerability with netgear routers. I have two netgear R7000 running older firmware V1.0.9.42_10.2.44. I do not upgrade because every newer verson of firmwar...
- Mar 09, 2020
Greetings,
See the following link...
https://www.netgear.com/about/security/
Scroll down a little bit. It shows all of the security advisories, models affected, and the minimum version of FW required to be protected.. In the case of the R7000, 1.0.9.42 has protection against the recently discovered exploits.
microchip8
Mar 06, 2020Master
What are those vulnerabilities? Can you point to a link?
- schumakuMar 07, 2020Guru - Experienced User
- shadowsportsMar 07, 2020HeroThe list of affected routers is extensive. There are over 50 affected models. microchip8, the 7800 is that the top of the list although I see you're running Voxell FW.
Not trying to panic everyone but this is one of those situations where everyone should really update their firmware.
The vulnerability rating on some of the affected models is 9 out of 10. This should not be ignored.
I've already upgraded my R8000P. I'm going to do my R6400 and Orbi's this weekend. My R7000 is off right now at the summer house.
This is one time where not upgrading could have serious consequences for people.- microchip8Mar 07, 2020Master
I read through the thread on SNBForums and it appears that Voxel's firmware is not vulnerable. He fixed many (all?) issues in his firmware a few versions back and I run the very latest of his
