cmartorelli's avatar
Mar 06, 2020
Security flaws if only used as access points
I have read the recient artical about the vulnerability with netgear routers. I have two netgear R7000 running older firmware V1.0.9.42_10.2.44. I do not upgrade because every newer verson of firmwar...
  • shadowsports's avatar
    shadowsports
    Mar 09, 2020
    Greetings,
    See the following link...
    https://www.netgear.com/about/security/
    Scroll down a little bit.  It shows all of the security advisories, models affected, and the minimum version of FW required to be protected..  In the case of the R7000, 1.0.9.42 has protection against the recently discovered exploits.
