philippejamel
Jan 24, 2022Follower
security in no managable switchs
hello normaly we use managable switch to change config in order to not take car, 60 miles but all administrators change switch in their office, after take car, 60 miles etc (time lost) so i...
michaelkenward
Jan 26, 2022Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge. Routers and switchers don't have much in common.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Discuss Ethernet Switches Plus and Pro Managed
I will ask the Netgear moderator to move your message.
- FURRYe38Jan 26, 2022Guru - Experienced User
If the nework or router your trying to configure doesn't need any kind of switch management then of course, you can use a non managed swtich. Just for traffic pass thru and if thats all you need to gain access to the router remotely, then a non managed switch would be preferred to use. No need to have anything addtionally in the path to the router. Un-managed switch are easy to connect and pnp. No configurations needed on them. Security is configured at the endpoints (PC/Router) if and when this is needed.
philippejamel wrote:
hello
so i think managable switch is not good (just to see on or off on the map!), price too
security is not the job of the switch, do you think is good to buy no managable switch ?
