Heihei123's avatar
Heihei123
Follower
Jan 21, 2021
Security Question (R7000)
While I tried to change some wireless setting on 192.168.1.1, it required me to enter serial number as usual. But I forgot my the answers of security questions. Then I follow the guide to reset my router, but it automatically connected as ususal without any new set-up. Anyone can offer me some helps please?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    You need to make sure you hold the reset button for 10+ seconds and the lights should flash that will reset your default login to admin/password.
    DarrenM
