rammy304
Sep 04, 2023Follower
security software necessary?
hi, i called the netgear to check my router since my internet was down for a couple days and they told me the security software/program for the router has been expired so thats why its been blocking ...
Sep 04, 2023Guru - Experienced User
No required and if you don't want it, get a refund.
You may need to contact your back or CC to reverse the charge.
