Powerbean
Jan 02, 2021Follower
Security update to latest firmware for wndr3400
I bought this router in 2016 and have never had a problem with it. I have received several emails over the years from Netgear telling me that there is enhanced security updates to the firmware. To da...
Jan 02, 2021Guru - Experienced User
What modem do you have?
If its connected to a modem/router combo device, you might have a different default ip address for the router.
if so, disconnect the router from the modem/gateway. Then you can open a command prompt and type ipconfig
the default gateway should be the ip address for the router. Try using that to access it.
You can download the firmware and view the instructions here:
https://www.netgear.com/support/product/WNDR3400v1.aspx
make sure you have a v1 as there's several versions. Use the drop down box to select your version.
