bobnfran
Jan 22, 2022Follower
Securiy Key R7000p
Brand new and very tech-challenged. How do I find security key for to connect new router. Scanner did not work for me. All help is appreciated. Thanks in advance, Fran
michaelkenward
Jan 23, 2022Guru - Experienced User
Start by explaining the problem and what you are trying to do.
What is asking for a "security key"?
What does "Scanner did not work for me" mean?
If you are talking about the wifi "passphrase"(password), look at the label on your router.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
