Fce
Apr 25, 2022Follower
Seems like my Local access is gone. Now, I have anywhere access, which I can not run speed test,
I have no idea what caused this problem. Everything was working fine last week? Router R7900P . Firmware is up to date.
michaelkenward
Apr 26, 2022Guru - Experienced User
Any chance of explaining what the problem is?
Burying question in a long subject is a bad idea. Not enough room for a proper description.
What are you doing and where does it go wrong?
Is this something to do with using an App with your device?
That's what Anywhere Access is about.
Which app? Android? iOS?
Sadly, " up to date" is not a reliable guide. A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
