i58_Jess
Feb 13, 2023Aspirant
Select ethernet name on an R7900P Router
When I connect an ethernet cable to this router, it defaults to Netgear93; can I select a different name? If so, how?
microchip8
Feb 13, 2023Master
Thanks for providing so much info!
Where do you see that?
Which firmware version?
What device(s) are you plugging in?
Have you looked in http://routerlogin.net or http://192.168.1.1 ?
- i58_JessFeb 13, 2023Aspirant
Win11 shows that I am logged into Ethernet to Netgear93. At the same time, I am logged into Wireless SSID i58 (one that I created). What I want to do is log into Ethernet i58 not Netgear93.
I am currently logged into the R7900P.
- FURRYe38Feb 13, 2023Guru - Experienced User
Disconnect from the SSID on the router or disable the wifi radio on the laptop.
You should be only connecting to one or the other at separate times.
Okay, I will only use Ethernet or Wireless.
However, am I able to set the Ethernet to other from Netgear93?
- microchip8Feb 13, 2023MasterThis is a Windows setting, not a router one. It's Windows that assigns network names so look around in its settings.
